Tire wear
Tire wear
Need a little help diagnosing from you front end doctors. Passenger side front tire is bald as a cucumber on the outside 2". Remainder of the tire tread has worn evenly. Driver's side has even wear all the way across. I know I've got a problem, just don't know where to start. Obivously, she's leaning out hard on the passenger side. Before I take it to a front end shop and have them charge me my first born child, thought I'd ask the experts. What do you think? Kingpins? or just bushings? How do you check?
- l1k2gadd
Put a floor jack under the right I-Beam and lift the tire off of the ground. Grasp the tire on the top and the bottom and see if the wheel pushes in and out. If not, try grasping the tire on each side (3:00 and 9:00 positions) and do the same thing.
When you find the play in the wheel take a look behind the wheel as you are pushing and pulling on the wheel.
This is how I found that my kingpins were bad, BUT my tires were worn on the inside, real bad.
Too many projects, too little time, but.. lovin' it!
2-1966 Mustangs (one 289-2V and one 200 6 Cylinder),
1-1990 7-Up 5.0 Mustang LX Convertible (second one),
1-1990 7-Up 5.0 Mustang LX Convertible (third one, for parts only)
1-1990 7-Up 5.0 Mustang LX Convertible (fourth one, best of the bunch).
1-1992 "FEATURE" 5.0 Mustang LX Convertible (only one)
1-1993 "FEATURE" 5.0 Mustang LX Convertible (one of the yellow ones)
re: Tire wear
I went through whole front end rebuild (all) and in hindsight, I should have just tried changing the drag link/tie rod end (whatever they're called). When I got mine off, you could shake it real hard and they'd rattle. New ones are very firm and require considerable effort to move at all. You might try cleaning out and greasing your kingpins and front end first to see if helps. Kingpins have caps, top and bottom, you can take off and scrape all old congealed grease out and blow old grease out of zeirdt fittings. A $20 harbor freight air powered grease gun sure is handy.
- AlleyCat
re: Tire wear
Sarge, check all of the suspension while you're under there.A broken rear spring can make it lean to one side.This in turn throws the geometry of the front suspension out of line.
Clay
re: Tire wear
Rotten bushings up front can change the geometry.
'72 F250 Ranger
Disk brakes, PS/PB, 360 2bbl
Current condition : beloved 'beater'
'70 F250 Camper Special
Currently in the shop, totally stripped
'72 F250 Ranger
re: Tire wear
thanks guys! All good info. That's what I was looking for.
