in bed tool box removal -found the trick to getting them out
1971ford
Post by 1971ford »
im stuck removing the inbed tool box from my 69 ranger. i cant get the big huge screws in the bed loose. how are you suppose to get this thing off?!
-Ryan
is it rusted or is it just tight? if its rusted spray some pb blaster on the bolts and let it sit for a while. if its just tight use a breaker bar and maybe a cheater pipe if you have to.
1971ford
Post by 1971ford »
well its not really the tightness, its the fact that we dont even have a phillips that huge. its is painted over too, so i will give it a squirt.
thanks
-Ryan
ok you need one of those impact drivers also. you seen that thread about those didnt you. it was in the engie forum
1971ford
Post by 1971ford »
i missed it i guess.
-Ryan
1971ford
Post by 1971ford »
well i just learned what an inpact driver is :D
but still, i dont think the impact drivers will have a philips head this huge. i took a pic but you cant see how big it is in the pic. so its not worth posting
-Ryan
71Ford100
re: in bed tool box removal
Post by 71Ford100 »
Can you cut it from the underside with a torch?
Lance Peters
i tried to get a pic of the size of the srewdriver head on one my impact drivers and it was just a black blur blob. i am sure it will work if you use it. go down to the store and check one out. you can probably see the bits it uses . that will tell you wheather or not it will work. im sure it will.
1971fordsdad
Re: re: in bed tool box removal
Post by 1971fordsdad »
71Ford100 wrote:Can you cut it from the underside with a torch?
Please refrain from using words like "torch" when talking to my 14 yr old. Remember, this truck is in a structure adjacent to my flammable house. Actually, having once owned a muffler shop, I would love to get a nice torch setup for the house. It would save money on penetrating oil when dealing with those rusty bolts!! And, Ryan, I might still have my old impact driver in the bottom drawer of my tool box.
Mugwump
Post by Mugwump »
:lolprev: :lolprev: :yt:
'65 F100 Custom Cab Shortbed - current project
'69 F250 Ranger CS (Tug) - P/S, P/B, AC - 390/C6/D60 - Reef Aqua/Wimbledon White [sold]
'66 F100 Custom Cab (Shep) - 352/4sp/9" - Wimbledon White [gave to OldDawg]
1971ford
Post by 1971ford »
dont worry guys, i got it ALLLLLLL figured out :thup:
(i must have been falling over when i took this pic lol )
-Ryan
67mann
Post by 67mann »
:lolprev: :lolprev: :lolprev: :lolprev:
1971ford
Post by 1971ford »
yeah lol but this was done at the welding shop :D
-Ryan
RedneckTexan
Post by RedneckTexan »
Is that you or hal cuttin? :?
John
68 F-100~68 F-350~69 F-250~69 F-100
76 F-150~78 bronco~78 bronco
http://oldfordcrewcabs.com/
