metal wiping prep
metal wiping prep
i have some parts all sanded down and i'm ready to wipe the finger prints off. what about mineral spirits. that is oily isn't it. what should i use.
Banjo
re: metal wiping prep
Post by Banjo »
lacquer thinner, carb cleaner or brake cleaner or denatured alcohol. mineral spirits does have some residual petroleum distillates in it, I think, or have been told that in the past.
ok brake and carb cleaner. i knew it was something i had around here.
basketcase0302
Post by basketcase0302 »
I've always used laquer thinner and had good results.
Never used any of those others.
Basketcase
fitzwell
Post by fitzwell »
some sort of prep solvent, Klean easy, etc. You dont want any residue. Do not use carb cleaner, or mineral spirits, as they will leave a film behind.
Banjo
Post by Banjo »
wow, I didn't know carb cleaner leaves behind a residue? Is it oily? I have never noticed that. I mostly use lacquer thinner for most anything. There is also stuff sold alot of parts houses and Wally world too, called 3M wax and grease remover that is good
