upside down i beam?
- boots
upside down i beam?
I was searching some ford pictures of 2wd trucks and I found this picture. Are thoes i-beams upside down?
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- 460 crew
re: upside down i beam?
Looks like they are, had to go outside and look at my brothers 69. Lookin at it it seems you might be able to get like 2in maybe 3in of lift. Ive never torn any of those parts apart yet so I couldn't say if it could all be installed upsidedown without any machine work but I'd certainly be interested.
- Heavenlyfire
if it is that easy I would be real interested. The modified I beams are about $800 for a set just to get 2 - 3 inches. I will have to investigate this one
- Heavenlyfire
just went out and looked at it all, did a little "eye ball" measuring. I think it could be done. I just might have to try it next week when I have a couple of days off.
- 460 crew
LOL I was out there with a tape a few minutes ago also. I was thinkin it might work also, but it might throw off the alighnment just a hair and the brake hoses might need to be lenthened. other ? is if the bolt and nut that holds the spring down on the mounting spot for the radius arm can be flipped and poked through the other way.
- Heavenlyfire
Ok, Here is an idea my wife came up with, yes my wife, she likes to play too.
What about instead of just flipping them upside down, also change sides. That would fix the arm problem, right?
- 460 crew
heavenly meet me in the chat or email me at crewzin70@cox.net
- Heavenlyfire
That's it, I have decided to give this a shot next Thursday. I have almost 3 full days off and that should give me more than enough time. If anyone has suggestions for me, let them fly.
- boots
good luck, post some pictures if you complete it.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- greasemonkey060
looks like it, but wouldnt you need taller coils? or maybe lower the upper coil tower?
'64 F100 SWB 8" notch, & triangulated four link w/ 2600 Firestone bags out back.
'67 F100 SWB STOCK.
'67 F100 SWB STOCK.
- Heavenlyfire
I am not sure but I don't think so. It looks like the top of the I beam would be in the same place.
- boots
edit: i was mistaken
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- 71-F-250SC-72-F-250C
I saw them do that on a show of junkyard wars but the wheels were I guess you would call it...toed in real bad, that would have to be adjusted. It was like this \ /
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic.
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
[quote="ToughOldFord"]
72 f-250 Custom
03 mach1 mustang
- boots
ok ok, i understand why it would give you a lift now, my brain wasnt catching it before, a little slow lately, just went outside to check it out and it looks like it can give a lift, im excited to see what happens with Heavenlyfire and his i-beam project. pls post pics and tell us if any modifications are needed, also how much of a lift you get, I would greatly appreciate it!!!
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- Heavenlyfire
I am going to start tomorow with all of the measuring and trying to figure out if it will work on paper first. So far, looks good, full steam ahead. Wish me luck
