Front end
Jason
Front end
Post by Jason »
Some time ago i seen a post on using a dakota front end kit and it had some links but it was some time ago. does anyone remember this and if so have the link for it??
1967 F100 SWB step-side, 300" 6cyl, T-18 transmission and Dana 60-3 rear end with 3.54s
MadMaxetc
Post by MadMaxetc »
http://www.industrialchassisinc.com/
I am putting one on my 63.
Give them a call and tell them what you have. Steve realy knows his stuff and the parts are top knotch.
Dan
FORD Girl
Photobucket Pictures
Jason
re: Front end
Post by Jason »
do you use a donor truck if you get just the cross member? how hard is it to make the bolt patterns match a ford bolt pattern (I am pretty sure I am going to go with Independent Rear Suspension and want to keep the bolt pattern the same all the way around.
I will be asking lots of questions for those who are willing to help I am starting to collect all the parts to frame off my 67 and i will also add more before pics soon.
layedout72
Post by layedout72 »
the owner is over on th HAMB (www.jalopyjournal.com) as "el polocko" or similar. He rally knows his stuff. If you are wanting to lay out fully, your gong to need to "Z" the front end 3 inches, as our frames just dont kick up at all like dodge and chevy frames. The 61-66 kit DOES fit our trucks from what he says.
Also, you use a donor clip for suspension.
Jason
re: Front end
Post by Jason »
thanks for the info
does anyone else have any ideas? or info?
