body sealer before primer, or the other way 'round?
Ranchero50
Post by Ranchero50 »
Got the 3m brush on sealer for the body seams, also have the high build primer to smooth the body. Neither say anything about the other. Which goes on first?
Jamie
just guessing. i would say the sealer on the seams first.
67 ford f100s rule
Post by 67 ford f100s rule »
i agree with fordman.
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
Steve302
re: body sealer before primer, or the other way 'round?
Post by Steve302 »
Hello,
The 3M seam sealer will do fine over metal or any well prepped surface.
You need to give that stuff several days worth of dry time before you load up your high build primer. Even then, you will most likely get some crazing in the primer that was applied over the seam sealer and it will show up in the paint too, but seam sealer is usually in places where its not that noticeable.
Steve
layedout72
Post by layedout72 »
Primer absorbs water, so you want the sealer first. When done with primer and body work its smart to use an epoxy primer as it will seal the truck completely. The epoxy does not absorb water.
