F100 BMC on Camper special?
Hello, just picked up a 67 camper special. Bare bones as it get. 300-6 no power brakes. Master cylinder appears to be seized in bore. Can I use my power brake booster and master I just took off my 71 f100? - Converted 71 to dent side discs, so I've got the old usable stuff laying around. Any ideas on if it'll work? Thanks, Bart
- seattle67
re: F100 BMC on Camper special?
These may help answer your questions:
http://www.fordification.com/discbrakes01.htm
http://www.fordification.com/Ibeams&spindles.htm
http://www.fordification.com/clutch-brake-brackets.htm
Dan
"I plan to start procastinating immediately"
Dan, thanks. I see the problem with the rod etc. I was mostly curious if the hydraulics would work correctly, since the 67 probably has larger front and rear brakes. Bart
