How to remove/install bump trim
- MaxKlinger
What is the proper way to remove and install the trim that runs along the bump on our trucks? I'm going to do this as prep work for the guy who will be painting it.
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
starting at the front of the truck there are some clips to unbolt from under the fender. the rest will have to be slide off or snaped off of the remaining clips. the door shoul have two bolt on clips at the edge of each door. and slide or snap the trim off the remaining clips . the bed is the same way it has bolt on clips that can be unbolted from the hole inside the bed up front. and one in the back unbolted from behind the tail light assembly. and the remaining clips are like the others.
re: How to remove/install bump trim
The simple way to remember: virtually all trim pieces are bolted on at each end and just snap onto plastic clips in the middle. The really short trim pieces (cab trim behind the door) are just bolted on at each end. You just need to find access to the nut from the backside of each panel.
