Car covers?
Mugwump
Car covers?
Post by Mugwump »
I just bought a rust-free '69 Ranger CS - and I'd like to keep it that way. The truck had a good quality stock-color repaint about 10 years ago, and it's showing its age, but still shines up ok. I'd like to milk another few years out of it before the next repaint if possible, so I'm thinking about how to protect it. Unfortunately, my garage is, um... occupied... yeah, that's it... with um.... woodworking tools and... um... stuff.... :oops:
Any suggestions on whether its better to cover the truck with a car cover vs letting it sit in the rain (California - no snow or salty roads)?
I'm concerned that moisture might build up underneath the cover and make it worse.
If you do use or recommend a cover, which is the best for my climate?
Thanks!
'65 F100 Custom Cab Shortbed - current project
'69 F250 Ranger CS (Tug) - P/S, P/B, AC - 390/C6/D60 - Reef Aqua/Wimbledon White [sold]
'66 F100 Custom Cab (Shep) - 352/4sp/9" - Wimbledon White [gave to OldDawg]
67 ford f100s rule
Post by 67 ford f100s rule »
since you live in california. You might not have a problem with it freezing to your truck. If it does it can be a (Expletive deleted) to get off. you would have to make sure it is fine or it will end up scratching up your paint.
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
