disc brakes for a 71
- slamons
Has anyone used LMC's Disc brake conversion or Master Brakes conversion kit? Was it fairly easy, or is a 78-79 switch over just as easy? And if so I am looking for a 78-79 set up.....
re: disc brakes for a 71
Any disc-brake truck from '73-'79 can supply everything you need, and at a fraction of the cost, since these trucks can be picked up for next-to-nothing. It's a straight bolt-up procedure. Have you read the tutorial?
http://www.fordification.com/discbrakes01.htm
