Got the steering column pullled so I can rebuild it with the
pwr steering shaft and paint before reinstalling.
Pulled the grille, bumper, and lower valence.
Only the two main rad support bolts left to remove support...
Pulling column
Column out
Rusted clip
Radiator support rust
(click on pic to enlarge)
The bad rust is only about the size of 1/4 of a dollar bill (or smaller)
I am debating about just cleaning the existing support up instead of replacing it... this is sorta what I have in mind.
1) Cut out the active rust to clean metal...
2) Use Eastwood rust encapsulator to kill the rest of the rust
3) Patch with sheet metal and fiberglass enpregnated resin
4) Paint
The floor pans also have a couple of small areas that could be patched the same way.
Anyone got any ideas or feed back ?
Thanks again,
KaptnKA
