por 15?
JWW
re: por 15?
Post by JWW »
Here is a FAQ from the POR15 website, also the contact info is at the bottom of the page. I spoke with a guy there once, he was very helpful.
http://www.por15.com/faq.asp
The guy I spoke with told me as long as I primered what ever I planned to paint later, I would be OK. He told me that sunlight weakens the POR15. It is "Pour Over Rust". Stops rust in it's tracks.
Here are some links to Keith's chop shop project where he used POR15:
http://www.fordification.com/mychoptop-p07.htm
http://www.fordification.com/mychoptop-p10.htm
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
re: por 15?
POR-15 should be viewed as a rust converter...it's definitely NOT a paint. That is, something to be used on exterior body panels. Yes, I did do it with my choptop, but it's still not something I'd recommend for anyone wanting to actually have a nice-looking truck.
POR-15 is great for stopping the rust and protecting steel...I look at it like a liquid powdercoating. It's very durable and long-lasting, if the proper prep work is done first. It doesn't like bare steel as much as surfaces with light surface rust.
Definitely use it on your frame, suspension, inside doors and behind fenders, under the bed, etc....but for the exterior body panels, just take the time to properly prep and paint with conventional automotive paint.
Banjo
re: por 15?
Post by Banjo »
I've used POR-15 and POR patch and Chassis Saver, which I thought was same but more economical.
hotrod ford
re: por 15?
Post by hotrod ford »
can this stuff be bought at your local auto aor paint stores?
HOWDY69
Post by HOWDY69 »
I have found it at
Auto paint stores.
Mustang specialty stores.
Hotrod stores.
69 F250, FE Specialties 410, CJ Valves, RPM Intake, Holley 4150,......10 Smiles per gallon
71 Clydesdale in many pieces; 302 roller motor waiting impatiently
hotrod ford
re: por 15?
found it at car quest today. i was really surprised! just have one more question though, does the frame have to be completely stripped of old paint or can it be left on as long as there is no rust? thanks
re: por 15?
POR-15 stands for Paint Over Rust. It gets it's best adhesion from slightly-rusted surfaces. Just make sure you clean the area well with a wire brush, make sure it's clean rust and that it's dry (definitely degrease it well) and you shouldn't have any problems.
