Engine's back in
shrektruck
Engine's back in
Post by shrektruck »
After putting it off much too long I put the engine back in the Shrektruck. It ended up getting a mild cam and lifters, Weiand aluminum intake, truck avenger 670 carb, 30 over pistons, crank polished, new oil pump, Hedman Elite headers, Flowmaster 50s (should have gone with the 70s or the hushpowers, 50s are still pretty loud)...What else???? Electric fans and a cleaned up four row radiator. I think that's it. Runs pretty good, I think I'll upgrade the alternator before the cross country trip though.
I'll take pics if ol what's her name ever finds the camera.
Matt
460 crew
re: Engine's back in
Post by 460 crew »
What kind of electric fans did you use?
shrektruck
I used two Hayden 3670s with the appropriate controller. They keep it quite a bit cooler than the stocker when waiting in line at In 'N' Out.
Right now they're mounted directly to the radiator but Ihave half the bracket fabbed up so they won't be hanging on the radiator. Itried for some good pics but the light is wrong right now.
here's pics of the rest of the job:
Matt
marz68
Post by marz68 »
that truck must sound good
460 crew
Post by 460 crew »
Lookin good!!
69F110
Post by 69F110 »
Looking good indeed! Sweet!
Steve Davis
Pastor and U.S. Army Retired
1969 F100 Ranger LWB, 390 and 3 on the tree
shrektruck
Thanks guys. It sounds good if you're not sitting in it with your fillings popping out!. Actually I used Flowmaster 50's and now wish I'd gone with 70s or hushpowers.
I like the sound but it drones if you're on the highway which I will be here soon.
Matt
customcrewcab
Post by customcrewcab »
wow they don't rattle :? looks like they touch :eek:
shrektruck
Must be the pic angle.
There is a good inch of clearance between them; I hate rattles...well, rattles or vibration from sloppy exhaust work. The challenge was getting equal lengths of pipe before the mufflers and routing them both down the passenger side so I could keep the aux tank.
Still not sure I like it. I may rip it all out and start over when I get a chance
Matt
tuff4rd
Post by tuff4rd »
Looking good :thup: I just installed the Elites and Flowmaster super 40's on my truck. I also ordered the Holley 670 Street Avenger, looks like we alsmost have the same setup.
Keep up the good work :clap:
71 F100 XLT Ranger
04 F150 FX4
06 F150 XL
1971ford
Post by 1971ford »
wow! it looks exactly like mine but cleaned up ALOT. thats nice!
i should rebuild my engine sometime. it really needs it.
-Ryan
Darlingtonpride
Post by Darlingtonpride »
Looks real good....
DuckRyder
Post by DuckRyder »
Looks good.
Putting tail pipes on it would probably quiten it down quite a bit, and change the rpm and speed of the drone.
Of course, you could scrap the flowmasters and go with Ultraflows... :wink:
shrektruck
I think the flow masters are coming off. And you're right Robert, The pipes gotta go back. I broke a cardinal rule and hurried a bit because of the move.
Matt
