a few oddball questions
Joshpow
Post by Joshpow »
I was wondering if there is any lowering spindles out there for our trucks. I also want to know if you have to drill to lower the back with the flip of the spring saddle. I want the most affordable way to get 2 inch front and 3 inch back drop without screwing up my camber or modifying the frame. I also wondered how much drop I could get in back from removing the helper leaf and flipping the saddle. I wont be hauling when I get done.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
theskytoucher
re: a few oddball questions
Post by theskytoucher »
there are no drop spindles for the suspension on our trucks they just wont work as to everything i have read about the idea!!!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
they do make drop i beams though. i think dream beams or something like that but it messes up your camber ive read.
ezernut9mm
Post by ezernut9mm »
the dropped i beams are the only way to lower the front without causing any camber issues. or you can use drop springs and have your factory i beams cold bent by a good front end shop. type dropped suspension in the search box and you can see all the different ways people have dropped the rear.
tybob81
Post by tybob81 »
If you do not want to cut your factory coil LMC truck sells a 2'' drop coil. They are not to bad on price and wont effect your camber to bad at all. As far as drop beams go the companys recomend you to use your factory coil or replace it with a new factory height coil when using there beams to reduce negative camber. I have LMC coils in front and a flip kit and c-notch from DJM on my 68 waiting to be put on. I just havent had time to do it yet.
Joshpow
Post by Joshpow »
Great info guys. 2 More Questions. Who could bend the beams for me if I use coils to lower? Does anyone know the average price for getting it done? Thanks for the help.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
ezernut9mm
Re: re: a few oddball questions
Joshpow wrote:Great info guys. 2 More Questions. Who could bend the beams for me if I use coils to lower? Does anyone know the average price for getting it done? Thanks for the help.
the price seems to vary quite abit. i think keith said there was a shop near him that would do it for around 50 or 60 $. the only place i called around me wanted around 135$ to do it and it was at a big truck shop. so i would just start calling around to the smaller garages and see if anyone does it. if not, call a semi truck shop and see what they want.
alignment shops bend i beams if they have the bender.
tybob81
Post by tybob81 »
Your best bet would be hit up an old mom and pop garage. They usualy have the ''old school tools'' to do the job. Another bet would be to check a shop that hop up old fords they might have the benders to do the job.
