Kingpins
Banjo
Kingpins
Post by Banjo »
should I be able to just push my new kingpins in my spindles by hand through the bronze bushings (new also)?? machine shop said that, I was figuring should be a little tigther? But, I'm basing that on old ones I drove out (they were frozen to ibeams).
Wes
Post by Wes »
no you shouldn't the new bushings need to be reamed after installed in I beams. every fit is different, the new parts can't be made to accommodate all the variables. The Bushings are made small and installer reams to fit.
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them :)
Banjo
re: Kingpins
Post by Banjo »
Let me rephrase. Should new kingpins need to be pressed in rebushed spindles/ibeam? Machine shop says kingpin supposed to be fairly loose only held in place by locking bolt/pin. I thought new kingpins should be tighter than that, I can push mine in spindle bores in and out by hand.
ima71 trucks are older
Re: re: Kingpins
Post by ima71 trucks are older »
Banjo wrote:Let me rephrase. Should new kingpins need to be pressed in rebushed spindles/ibeam? Machine shop says kingpin supposed to be fairly loose only held in place by locking bolt/pin. I thought new kingpins should be tighter than that, I can push mine in spindle bores in and out by hand.
once the bushing are installed and reamed, the kingpins should slide in and be held in with the locking bolt.
68 F100 soon to be on an 80's 4x4 frame and 300-4spd
69 F100 300-4spd
78 F150 300-3spdOD
Banjo
re: Kingpins
Post by Banjo »
I can slide these all the way "home" by hand, and was expecting greater resistance. Should they require tapping or anything? Forgive my naivity, I've driven 2 sets out w/hammer and based on that hellacious struggle these seems "too easy". Banjo.
Mooosman
re: Kingpins
Post by Mooosman »
Seems to me that if they were loose enough to slide all the way through by hand, then you would have too much play in the spindle assembly.
Did the machine shop hone or ream the I-beams? Or were the kingpin bores galled or chewed up?
Nick
1972 F-100 Custom SWB
there is not a press fit between the kingpin and the bushing. the bushings are reemed to the diameter if the kingpin. the kingpins should slide easily in the bushing.
69 F100 300-4spd
78 F150 300-3spdOD
Banjo
re: Kingpins
Post by Banjo »
thank you much, banjo.
