My in-cab tank gauge was not working due to a rusted/leaking float.
Short of buying a new one, what can be a suitable replacement? Any ideas?
It's got to:
1. fit into the tank gauge hole
2. be fuel resistant
3. be easy to make
4. Not made of any precious metals.
and of course.... FLOAT.
Old ones are tough to come by in the wrecking yards. Most are in the same condition as mine....
Brian
fuel gauge float ideas?
Moderator: Ranchero50
re: fuel gauge float ideas?
But a new float in it! COAZ9202B at your local Ford dealer for less than $6.00!!!!!!!!!! If it is a leaky float!
FORD BUILT EM TUFF WE BUILD EM BETTER!!
- Logan
Yeah, but
"Local Ford Dealer" is dead to me. After waking up the guys at the parts counter, they Himmmed and Hawwed about a 1967....
"1967.... uh..... did Ford make trucks back then???? well ya know, those parts are uh..... i don't know if I can order that... it's made of METAL??? We only deal in plastic parts here.... Have you tried the wrecking yard?"
(quote is exaggerated a slight bit )
Just my experience. They're worthless.
I'll look at LMC and other non-corporate vendors. Any home-grown replacement ideas are still appreciated.
Trust me I understand! infact the part # is a neutral # known to veterans of the biz. to work on these trucks! We are a big dealer and ha 63 in stock!
You can also get one from any of the mustang places.
if its a pinhole in a metal one, you can solder it.....
Recognition is the key to discovery
Thats what I did to mine...You need a pretty high wattage
gun, or a mild torch, so the solder will flow real well.
But I'd be ultra careful if using any kind of torch...
Could melt through if you got carried away...Myself,
I used a soldering gun with a 150w element, and it was
hot enough...I did that in 2000, and it's still working...
BTW...if you have a lot of rust, and the float stem
is rusted in place, you can usually free them up by
rust buster, and gentle prodding after it sits a while..
I gave the stem a shot of paint to try to slow the rust
down a tiny bit... MK
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
