can't figuar it
Nickabocker
can't figuar it
Post by Nickabocker »
ok I've been having brake troubles on my 67 for a bit and i finally thinking that the brake drums went bad replaced the front ones. The rear ones i haven't had a problem with yet anyways i replaced the drums and tightened the adjusting screw to where the shoes barely rub before they catch when brake is applied. So i got in to take it for a test drive and my brake light (the one that shines red down by the emergency brake releace thing, is still on and i can't figuar out why. so thats my first question WHY and then my scound question is my clutch was fine for awhile and then i got in to move the truck pushed it in and it didn't come up like it was surposed to. why is that?
Nick
ima71 trucks are older
Post by ima71 trucks are older »
there was a thread on resetting the switch in the brake valve.
Basicly you need to loosen the line on the side that didn't fail and apply a little brake pressure to recenter the switch
68 F100 soon to be on an 80's 4x4 frame and 300-4spd
69 F100 300-4spd
78 F150 300-3spdOD
Nickabocker
alrighty anyone know about the clutch?
nick
FLATBEDFORD
Post by FLATBEDFORD »
I gave up and unplugged the wire for the brake warning light.
Steve
My Photo Gallery
MadMaxetc
Post by MadMaxetc »
The switch sould reset itself if all is working right. I would remove the switch fron the distibution block and shoot a little WD-40 in there and make sure that slider is working.
The clutch soulds unrelated. It sounds like the bushings in the peddle are going bad and causing it to bind a little.
Dan
FORD Girl
Photobucket Pictures
Nickabocker
k I'm confused again i just replaced the drums as everyone knows and i did everything to the breaks that i was supposed to but it still leaks! i have a puddle coming out of the drum and can't figurer out why! can anybody help me!
nick
rjewkes
Post by rjewkes »
sounds like a lesking seal ot hte wheel cylinder.
rjewkes wrote:sounds like a lesking seal ot hte wheel cylinder.
I hate it when my seals lesk. ;)
Your wheel cylinders are leaking. Did you rebuild the ones you had or replace them completely?
Nickabocker
rebuilt them but now i'm thinking to go get some brand new ones again and replace them!
nick
re: can't figuar it
When you rebuilt them, did you hone the cylinders out?
Considering the low price of the complete cylinders, I'd just replace them rather than messing around with a rebuild. Not worth the effort anymore.
Nickabocker
no wasn't honed didn't think they needed them but oh well i will just replace them soon and just one more question how do i know what box my sterring box is?
nick
re: can't figuar it
Nickabocker wrote:...one more question how do i know what box my sterring box is?
nick
It's that box-looking thing at the end of the steering column.
OH! You meant what KIND? ;) :evil:
Is it power or manual? Since it's a '67, it should be a manual box, unless someone's installed a PS setup. The manual boxes were all Bendix. Bendix also made a power steering box for Ford for a couple years starting in '68, after than they went with the Saginaw box.
