How do I remove windshield trim
pyrofighting
Post by pyrofighting »
Just as the subject says, how do I remove the chrome window trim on my 68 F100? :?
1968 Ford F100 Custom Cab
A/C, Power Steering & Brakes, 360ci, Holley 600 cfm, Headers, Dual Exhuast
kaptnkaos
re: How do I remove windshield trim
Post by kaptnkaos »
Hey Pyro...
That's pretty easy. It is just fitted into a groove in the rubber seal.
I used a tack puller... looks like a screw driver with a bent end and a notch. It comes out really easy...
KaptnKAOS
pyrofighting
have a pic of that tool, or a place/ website to get one.
kaptnkaos
Post by kaptnkaos »
You can get a tack puller at any hardware store fro about 3 bucks.
I got mine at Harbor Freight.
You could probably use a regular medium sized flat screwdriver and a small flat piece of wood, just some to give you a little bit of leverage, it doesn't take much at all.
I just happened to have the tack puller in my tool box. You could heat and bend a screwdriver tip to do the same thing.
KaptnKAOS
I've always removed them with a flat-bladed screwdriver. Just get one end started and then set the screwdriver aside and slowly work the pieces out. The stainless won't bend very easily, unless you put a LOT of force on it. Just be patient and you can gently work it out all the way around.
JWW
Post by JWW »
:yt:
I removed the trim on my 67'. I got in to big a hurry and the trim started to bend. Just be patient. Remember to keep all your pieces together. The Winshield trim will have some screws as well.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
MadMaxetc
Post by MadMaxetc »
Don't forget you have to put it on durring the installation of the new windshield!
Dan
FORD Girl
Photobucket Pictures
