How do you clean aluminum rims?
- cghstrojan08
I have some aluminum rims I want to put on my truck. How can I clean them up?
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- Heavenlyfire
re: How do you clean aluminum rims?
I use to use Naval jelly. It works really good especially if your rims have some rust. If no rust, just soap and water.
- cghstrojan08
What and where do I get naval jelly? There is some pits kinda from rust from the threads from the lug nuts.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- cghstrojan08
I have tried everything that they sell at stores and nothing is cleaning them. I will try naval jelly. I talked to my dad and he will buy some tomorrow.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- trukcrazy
Ospho will cut through the oxidation and corrosion, then just polish as normal. It is avalable at most hardware stores, but I got mine at Ace Hardware.
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
- averagef250
I use diluted hydroflouric acid labeled "brite-lume" to clean the nasty stuff then polish with aluminum polish and a buffer. I got a few gallons of the hydroflouric from a guy who worked at a place that cleaned semi tractor trailers. Don't get it on your hands or you won't have hands anymore.
If you just want them to look clean and be done with them quick just get some coarse scotch brite pads.
