Best sized angle grinder for rust?
- 69rangerman
I'm gonna have to do my first exploratory paint bubble pop, and rust/body work soon. Understanding that I'll probably have to do some grinding back to metal what would be the best size of grinder or tool to do that with?
All I have right now is a dremel.
- lightning_msd
re: Best sized angle grinder for rust?
I have a 41/2" and it seems to work fine, you can get flap discs, cutting discs, wire wheels, what i usually do when fixing rust is strip the paint first with the wire wheel, then use a flap disc to sand it down, if its all the way threw then cut it out and patch it, if not than use some putty to fill the scratches, and go from there, good luck ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
1967 F100 "Lexxi" 352
http://www.fordification.com/galleries/ ... ?album=482
- averagef250
Black and decker make the best grinders if you're shopping. B&D grinders never die and work way harder. I've got 3 4.5"s and 5 9 inchers and they all get used very hard. A couple of them are from the 50's and never been taken apart. You only need the big ones for serious grinding, and be careful with them too. The big ones don't play around!
- RedneckTexan
I've got a 4 1/2 DeWalt and I'm very happy with it. ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- flyboy2610
4-1/2" Milwaukee. I prefer the paddle switch. It's mounted on the bottom of the handle and held down with the palm of you hand. I think that's a safer design than the standard on-off slide switch. If you have to let go of the grinder for any reason it stops on its own.
If you have a good air comp i like these.
http://www.harborfreight.com/cpi/ctaf/D ... mber=97187
Just remember dont get the metal to hot from any grinding as it will warp it.
Foggy
Foggy
Bought what looked like a worn-out 4.5" Makita with a cut power cord from a buddy that owns a pawn shop for $5. Replaced the cord and have used it hard for 5 years. Thats my testimonial
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
1989 Ford F150
- RedneckTexan
I have that same switch on my DeWalt to.flyboy2610 wrote:4-1/2" Milwaukee. I prefer the paddle switch. It's mounted on the bottom of the handle and held down with the palm of you hand. I think that's a safer design than the standard on-off slide switch. If you have to let go of the grinder for any reason it stops on its own.
For the hard stone kind i like this one for a non name brand it has a 7amp rating
http://www.lowes.com/lowes/lkn?action=p ... lpage=none
Foggy
Foggy
- 71PA_Highboy
hmmm...
I have 4 HF on the floor of the shop every day... 4 1/2 "
I have less than $70 in all 4.
One has a cutting wheel, one has a grinding wheel, one has a wire brush, and one has a flap disk sander.
Some may say these are junk, but I can go months without swapping abrasives from one to another, and if one goes bad, I have a spare on the shelf I bought last time they were on sale for $14.99 (with coupon).
Since I use them 1/4th as much, they will probably last me as long as your higher quality, more money, 100% use single grinder.
OK... So I am a little different...
Just my
Eric
Just my
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
