cab mounts
aramil
cab mounts
Post by aramil »
i noticed my front end was cricked on my truck the other day and i figured the owner before had used a high lift on the front bumper and twisted it but instead it appears my passenger side cab mount is totaly rotted out and is sitting on the frame, so i looked at the driver side and its gone too its just sitting on a one by four. if i stick another one under my passengetr side will it screw it up more and will the boards hold the wieght of the cab?
aramil
re: cab mounts
Post by aramil »
here is a pic if u look u can see that the bumper is even with the pic and the body is tilted
using wood to support the cab will work for a temp fix. but it changes the weigh distribution of the mounts to the center of the floor of the cab. its not a good temp fix really. a better temp fix would be to use two pieces of plate steel made into a L shape. and weld that over the top of your original cab mounts. that would be better than wood under the floor of the cab. of course the best fix would be to get replacement mounts for the cab and weld those in. if you dont have money to buy new mounts you can get used mounts from another cab from 67 -79 they will work. i am going to use a used cab mount that i took from a 78 it wasnt too hard to remove the old flooring from it once i cut the floor and mount from the other cab.
aramil
Post by aramil »
thats what i was thinking, im just trying to get ths cab levled tell i have the resources to get it fixed. it has already damaged my floor pan cause it bent around the frame and now my passenger floor board has a hump in it
72, f-100 ranger xlt, 360-c6, 2wd 84k miles.
77, ford f-150 custom 4x4, 400m-c6 SOLD
"the existence of flamethrowers is proof that someone, somewhere, sid to himself, "i want to set those people over there on fire, but i dont feel like walking over there to do it"
merclover
Post by merclover »
i just made mine i cut out a round piece of plate steel drilled a hole in it and bolted it to where the mount connects to the frame then buils off that worked out pretty well
68 mercury m-100 brand new 390/c6
