First, the instructions for the cab mounts are not very clear, and not all of the numbers match. The kit includes four pair of rubber bushings. Two upper and 2 lower for each of the four cab mounts. The lower rear bushings are the ones that the numbers do not match the instructions. It also includes washers, four bolts and four sleeves for the center of the bushings.
The bolts and sleeves are not the same length (Two of each length) and the instructions do not show which go where. Based on the bushings I decided the shorter ones went in front. Nevertheless, even with the shorter ones in front they would not tighten on the bushings. Since I was not planning to do the rear cab mounts until I pull the bed, I used the larger bottom bushings and got them to tighten up.
The radiator support mounts also do not tighten down on the rubber; all of the mounts appear to be identical.
Anyone have a similar problem? What did you do about it?
In addition, can anyone tell what the design length of the sleeves should be?
It looks like I am going to end up completely re engineering these things.
![Cussing :cuss:](./images/smilies/icon_cussing.gif)
