Cab seams *added picture*
big green
Post by big green »
I have a 74 ford f100, i realize this is a 67-72 site but the trucks are very similar and you guys know what you are doing. I was wondering it is ok to remove cab seems. there is a lot of rust on my seams and it would be easier to completly remove the seam instead of making a new one.
flyboy2610
re: Cab seams
Post by flyboy2610 »
You can remove the seam sealer and carefully weld up he seam, if that's what you are asking.
Welcome aboard, BTW!
RedneckTexan
Re: Cab seams *added picture*
Post by RedneckTexan »
big green wrote:...and you guys know what you are doing...
:lolprev: You haven't been here long, have you? :evil:
Last edited by RedneckTexan on Sat May 19, 2007 10:39 pm, edited 2 times in total.
John
68 F-100~68 F-350~69 F-250~69 F-100
76 F-150~78 bronco~78 bronco
http://oldfordcrewcabs.com/
GT-Racer
Post by GT-Racer »
Looks like from the picture you are talking about the firewall. I have quite a bit of rust there myself. I plan to cut out the bad stuff and form new panels out of a piece of clean metal. I havent decided yet as to whether I will make it look stock or eliminate all those "seams" and make a smooth firewall panel.
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
layedout72
re: Cab seams *added picture*
Post by layedout72 »
I personally am going to "shave" mine when I get to the point (if i do) of REALLY building it how I want it. I think it was purely install based, as far as why they are done like that. Just made it quicker/easier for the production lines.
ToughOldFord
Post by ToughOldFord »
:lolprev: You haven't been here long have you?
Oh, a wise guy, eh? :evil:
big green
Post by big green »
Yeah thats on the fire wall. I want to shave them aswell, i like the clean look. but I dont want to loose any streagth in the firewall either. Dont know of anything that would happen.
if thats the cab mount area it looks similar to one of mine. i am going to clean it up real good with a grinder and then weld the new mount in an por 15 the blank out of all of it. but yes you could cut the seam off and just weld it up if you want to.
Galaxie64
Post by Galaxie64 »
You could bead roll the patch panels if you shave it and need to patch a new firewall in, that would give you plenty of strength and look good IMO.
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
