2wd ZF 5 speed info
- averagef250
2wd ZF 5 speed info
I'm looking at buying a couple 2wd ZF 5 speeds, both have problems, but the problems are different between the two and I figure there's enough there to make one good one. BUT, one is from an F-450 and has the integral e-brake on the rear and the other is from an F-350 and does not. I've never worked on one of these with the integral e-brake and wondering how different it is inside? Are the mainshafts different? Thanks.
- 390Nut
re: 2wd ZF 5 speed info
Output shafts are likely different.
I don't see it listed in the knowledge base at this website, but you might contact them anyways to see if they have any information on that tranny.
Novak
Novak
Paul
`69 F100 390 4spd driver
- adrianspeeder
I haven't looked at a '88-'97 F-Superduty ZF with the parking break tailshaft, so couldn't tell ya if it is the same as a 4x4 splined shaft output or a 4x2 yoke. I'll look around though...
Adrianspeeder
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
- averagef250
Thanks. I've called around and got both answers- "yes they are the same mainshaft" and "No, nothing interchanges." I can't seam to find much info on the parking brake ZF's and it seams anything from just a manual to special ZF tools cost a FORTUNE.
Used to work on a fleet of ZF equipped SD wreckers. I would stay
away. They are expensive junk. The cases wear out and the endplay
goes too big. The synchros and and most everthing else cost a small
fortune.
fortune.
- averagef250
I've noticed that many transmission parts houses sell ZF cases for a small fortune. I know the early ZF5 has a big problem cracking bellhousings, welded up a few myself. Didn't know about the case "stretching" though. That makes sense why they sell them for so much now. NV4500 case- $80 ZF5 case- $450 ?????
Do you know if the '98-up ZF5 or the 1st and 2nd generation ZF6 speeds have the same case issues?
No not really. I would suspect though. They got rid of the SD's and got
cornbinders. And 1 GMC which was one of biggest "POS" I ever got to
work on.
work on.
Hey, I'll throw this out there. If it's a pickup, you rarely lean on it
to hard, actually know how to drive a "stick", it should be fine.
They are pricey to fix, is all I was trying to convey.
- averagef250
- Ranchero50
Yeah, they aren't impossible to work on either. The parking brake tranny is actually a 4x4 transmission. Unbolt the brake and the transfer case will bolt on directly. Only real tripping point on these is make sure the gear ratio is the same between the trannies or nothing will swap. Found that out on the '89 diesel wrecker out back. Tried to put the guts from a 460 2wd truck in and they wouldn't work with the PTO... Different ratio.
What's wrong with them and where are they going?
Jamie
Jamie
- averagef250
