Why does my tranny squel and grab?
RandyBee1
Post by RandyBee1 »
I have a 3 on the tree. Why does the tranny make a squeeling noise when I put the clutch pedal in? It also grabs when I let it out. Any ideas?
I replaced the clutch, pilot and throw out bearing last year I did not resurface the flywheel but just did, and have not installed it yet!
Thanks,
Randy B.
ToughOldFord
re: Why does my tranny squel and grab?
Post by ToughOldFord »
The squealing when you push it in is usually the throw out bearing. The grabbing is flywheel or pressure plate's warped or the clutch dish is contaminated.
RandyBee1
Post by RandyBee1 »
Thanks, I put a new throw out bearing in last year, maybe I'll replace it and see what happens. I just had the flywheel turned down so that should stop the grabbing. The clutch disc itself is clean. thanks again!
Leadfoot
Post by Leadfoot »
the grab also can be caused buy a worn bearing slide, you know the housing that the though out bearing rides on.
the squeal is normally the pilot bushing being dry, you use a bronze bushing right?
but if it more of a howl its likely the though out bearing.
WHAT ?
RandyBee1
Post by RandyBee1 »
Yeah I used a new bronze pilot bearing, new throw out and new clutch disc
I'll check the slide to make sure. It'll probably be a week before I put it all back together. Thanks! Randy B.
Jake11
Post by Jake11 »
Did you lube it good before you put it in?
RandyBee1
Post by RandyBee1 »
I lubed the crankshaft bore that the pilot bearing gets pressed into. I know the old pilot bearing was dried out because I had the tell tale chirp sound everytime I shifted. I really do think my squeal is from the throw out bearing. Just for the hell of it I'm going to check the bore run out and the face run out.
Jake11
Post by Jake11 »
Some T/O bearings have a zerk fitting on them.
