Questions about powder coating?
I have not done any or had anything coated but was wondering if it can be done over body filler? I would assume so but not sure. ANyone know any benefits other than durability? I am sure I will edit this later with more questions but this is good for now. Thanks for any help.
[quote="MOST OF ALL, pray about it. If God doesn't want you to go, he will make it clear.[/quote]
1967 F-100 Longbed (project truck) For sale $1200 http://www.fordification.com/galleries/ ... ?album=710
http://www.fordification.com/galleries/ ... ?album=726
1990 Blazer (offroad toy) 7 in. lift, 37 in goodyear MTR's
2000 Ford Focus (DD/commuter car) ABOUT TO BECOME TARGET PRACTICE!
2005 GMC 2500HD Ext. Cab Longbed (Towrig for the blazer)
2006 Kaufman 20ft steel deck car hauler (The only way the Blazer sees the road)
re: Questions about powder coating?
No, standard body filler will melt when the powdercoated part gets put into the oven used to cure the powdercoating.
You could probably use some kind of steel filler, but I've never looked into what could be used.
Well that sucks! I was thinking of having my frame down when I get everything torn down but I want the frame to be smooth so maybe I will just have to be really careful welding and grinding. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
- 71PA_Highboy
There is an aluminum based body filler that is made for being under powdercoating that works well.
The problem with standard body filler is that it is non-conductive, and the electrostatic process used to apply the 'powder' dosn't work.
HTH,
Eric
HTH,
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- FoMoCo
USC's All-metal is advertised as powdercoatable, but I've never had any luck with it. Are you building your truck for show? Powdercoat will hide many imperfections.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
Re: re: Questions about powder coating?
Originally I was not planning on building for show. I have changed my mind now thiough, with the paint scheme I have decided on I just think the paint will look way to nice to not have the frame/ underside and the engine bay look good too. So I guess I am going for a show look, but nothing extreme. I have also decided to build my other 67 for a driver (don't tell my wife yet she still thinks it is a parts truckFoMoCo wrote:USC's All-metal is advertised as powdercoatable, but I've never had any luck with it. Are you building your truck for show? Powdercoat will hide many imperfections.
Nick
Thanks for the information about the conductive body filler. I will have to check into the price of it. I may just end up painting the frame.
- GT-Racer
I am watching how this turns out. If you look at mine in my project updates page, I will give you a little advice. Go EASY with the grinder. I filled a bunch of 1/4 inch holes, only to end up with silver dollar sized low spots when I got grinder happy. So I think mine will be getting a skim coat and por 15 probably.
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....![Smile :)](./images/smilies/icon_smile.gif)
