Removing Front Cab Mount Rubber Bushings (Tricks)
DuckRyder
re: Removing Front Cab Mount Rubber Bushings (Tricks)
Post by DuckRyder »
Wheres that drill/sawzall smiley?
Got them out with a uni bit.
4x4x4crewcab
Post by 4x4x4crewcab »
I am having the same trouble. Any pointers
Mark
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
DuckRyder
Post by DuckRyder »
It appears that the factory ones interlocked.
If you look at the side that has the larger opening you will see two notches.
The other washer has two tabs that sort of lock them together. It looks like at one time if you aligned the tabs it would come apart.
Mine took a unibit to drill them out.
The new ones from D-C LOOK NOTHING LIKE THE OLD ONES its one of the few (only?) parts that I've gotten from them that I wasn't very impressed with.
4x4x4crewcab
I have managed to find all the original NOS Ford parts for the cab mounts (except a center spacer of somekind for each location) The new stuff maybe a bit different as I don't see any lock tabs. I just don't want to cut something in the center of the old mounts I may need? The truck is not at this location but I will look for the tabs on Sat.
Mark
1999 Ford Windstar
DuckRyder
Post by DuckRyder »
I think I can get you some pictures tomorrow.
Don't suppose you have a line on another NOS set? :hmm:
4x4x4crewcab
Pictures would be great. I found these by the single piece. Ford didn't sell them in a set. I would be glad to search for whatever you would need the only drawback is the shipping it may be a 1 here,1 here,and 2 here kinda deal.
If I can't split mine I may just forget it? If I recall from the catalog there was a slight difference in some of the numbers between 2wd and 4wd? and then again some of the original numbers I had looked up had changed a time or two so I can't say for sure if there is a difference. But would be glad to (this weekend) retrieve the mounts from the shop and take a photo.
Mark
1999 Ford Windstar
71-F-250SC-72-F-250C
Post by 71-F-250SC-72-F-250C »
I used a old rachet extension, a socket that was small enough to fit in the bushing and a hammer and hit it a few times and it came out. I did this with the bushings up front and the bed bushings as well as the cab bushings. make sure you have a crappy extension though.
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic. :)
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
[quote="ToughOldFord"]
DuckRyder
Post by DuckRyder »
I tried all sorts of punches, sockets and extensions. :x
This is the only one that I managed to get out more or less intact. I don't even know if it is a cab mount or radiator support mount.
Stand by for crappy pictures.
DuckRyder
Post by DuckRyder »
More:
What I did to get most of them apart is drill the top of the washer with the smaller tube, causing the small tube (and thus the tabs) to separate.
A "UniBit" worked pretty well for this.
4x4x4crewcab
Thanks for the photos. I will try again to remove these on Sat/Sun
Mark
1999 Ford Windstar
willowbilly3
Post by willowbilly3 »
While we are on the subject, does anyone have a good trick to hold the bottom of the rear cab mounts to get the bolts out? I was trying to save the ones from the truck I parted out and finally just torched the bolt heads off. It seems like in the past I had a helper under there with big channelocks who was teaching me new variations of profanity that I hadn't heard before.
