brake booster ?
- shortbedCUSTOM
brake booster ?
just picked up this booster at a swap meet last weekend. It came off a '71 and I want to put it on my '70. one question though, what is the hole in the front for? is it for the vacuum line, and if so, how does the hose stay in there?
Carlos
Carlos
re: brake booster ?
Yes, that is where the vacuum hose goes. A plastic elbow is inserted into the hole and is held in place and sealed by the rubber grommet. The vacuum hose goes from the engine to this elbow. I'm at work right now or I'd post a pic of one for you.
- shortbedCUSTOM
re: brake booster ?
well, I guess I have to go back to the junkyard and see if I can find that elbow you're talking about.
- tazzman68
re: brake booster ?
The elbow, and grommet should be available at your local parts store for less than $10.
- 68F250
re: brake booster ?
The elbow fitting has a built-in check valve.
- shortbedCUSTOM
re: brake booster ?
anybody have a picture?
re: brake booster ?
These are about $10 new, depending on where you go.
- shortbedCUSTOM
re: brake booster ?
thanks, that'll help.
- willowbilly3
re: brake booster ?
I'm guessing one will work off almost anything, they all look to be about the same.
