another welding question
lightning_msd
Post by lightning_msd »
ok, so ive finally decided that i want shielding gas, because im sick and tired of brushing and hammering to clean everything. on the hobart forum keith give me has a welding 101 page. it talks about for steel use argon 75% and CO2 25%, im just wondering what if i use just argon on steel, since i have problems with burn threw on body panels, and argon doesnt look like it penetrates as deep as argon and CO2 mix. any ideas?
thanks
Randle
re: another welding question
Post by Randle »
Flux core welding penetrates more then when you use a shielding gas, and argon is a hotter weld then C25 (75% argon - 25% Co2). You will be much happyier on mild steel sheetmetal with C25.
lightning_msd
thanks randle, i just thought since aluminum is a softer metal and pure argon is used on aluminum, i just thought it might be good for steel. maybe its because i have flux core that im burning threw, i should go pick up some different wire then too. again thanks
flyboy2610
Post by flyboy2610 »
Yea, you want to use solid wire, and not flux cored with gas. For sheet metal I would use .023-.025, for heavier stuff use .030-.035. The gas will help to cool the weld, as well as provide protection from oxygen, so it will help to reduce burn throughs.
Randle
Post by Randle »
You will have a much nicer weld with less burn thru with solid wire and C25. Also go to a the smaller .023 wire.
lightning_msd
thanks guys, im starting to get the hang of things here :thup:
Big D's 69
Post by Big D's 69 »
I use the C25 and .025 wire and no real problems with burning through unless the sheetmetal is paper thin. Not one single burn through with putting in my bed side the other day.
jbanks
Post by jbanks »
:? :? :? I'll never learn to weld. :doh:
Big D's 69
Re: re: another welding question
jbanks wrote::? :? :? I'll never learn to weld. :doh:
Thats what I thought, but I was a quick learner and got pretty good real quick. :thup:
kid
Post by kid »
Sheesh all that work and I just pick up a gas torch and zip I am done.
