PST Pivot Arm Bushings - Is this right?
I think this is pretty straightforward but I just want to make sure before I bolt it up. Does the extra ring slide over the bushing and bump up against the head?
71 F100 302/3.03 Project Truck Underway
- SportCustom
Nope, once the bushing is installed the ring goes over the excess thats hangs out from the I-beam. Press the bushings in just like the one on the top in your picture. Then once it is installed you will have a lip sticking through, thats where you install the ring just before sliding it into the cross member.
Does that make sense?
Todd
Todd
1970 F-100 Sport Custom
390 FE
CV/8.8 Swap
390 FE
CV/8.8 Swap
re: PST Pivot Arm Bushings - Is this right?
Ahhh, I think I understand kemosabe. So it will go over the small end sticking out of the metal housing. I don't mess with the big end?
Thanks!
Thanks!
