Motorcycle Pop-Up Gas Filler Cap
Randle
Post by Randle »
How do you guys think this would look. I am planning on smoothing the inside of my bed ( like the picture below) and have mounted the gas tank above the spare tire. But instead of the gas filler door like the picture, I am thinking about using a motorcycle Pop-Up Gas Cap like the one in the bottom picture. I think it would be a lot less noticeable.
lightning_msd
re: Motorcycle Pop-Up Gas Filler Cap
Post by lightning_msd »
randle, where do you come up with these ideas? that looks awesome, i myself was looking for a way to make the filler door not noticible. either one of them looks good to me :thup: you should write a book on all these ideas you have, i know i would buy it :D
Big D's 69
Post by Big D's 69 »
I think it would look good so long as you can make it work.
CA180
Post by CA180 »
Seems like it would be a pain to put gas in that one with the door inside the bed.
:yt:
Randle
Post by Randle »
Just thinking these fillers are small enough they could even be mounted on top of the bed rail. That would still have them hide from the side.
rjewkes
Post by rjewkes »
or even if done right in the wheel well back there coming throught he top.
wt4speed#2
Post by wt4speed#2 »
I like that idea . Keep in mind a cycle tank neck fuels into a virtually open vessel , the truck tank neck feeds into a tube type opening, and with the new recovery set ups on the gas dispensing pumps this could create a fueling concern. I only brought this subject up because of an experience I had.
In about 99-2000 I was a member of the local VFD, our EMS dept suffered the loss of an out dated back up ambulance and had just order a pricey new one , our frontline that we were running caught fire and another ambulance company offered us a deal on a demo unit that was totaly state of the art and had quite a few prototype accessories , one being their redesigned fuel filler access "hatch " which used a marine type neck integrated into oem tank accessories . Long and short the blamed thing took forever to fuel (ems service "not good") and would never completely achieve a full tank (rural ems "not good" too). they ended up redesigning and using factory necks ,filler hoses and mounting. Even then due to the body config. and hose routing truck never fueled right.
Sorry so long just thought I'd share
Tony B
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
ICEMAN6166
Post by ICEMAN6166 »
i know of guys who installed the mustang tank under the bed to get the behind seat tank out but used a hinged type boat cap.
http://fordtruk.com/forums/album_picm.p ... user_id=42
Randle
Post by Randle »
Sorry to take so long to reply, but I put the wife in the hospital Saturday morning and we just got back home, everything is OK for now.
To explain what I am doing a little more, I have already modified a 73 frame to install my body on, this will give me front disc brakes plus the gas tank above the spare tire. It will also put the rear axle the same width as the front. The motorcycle filler can be welded to the top of the 73 filler tube with a little modifing.
layedout72
Post by layedout72 »
they can be made to work, a lot of minitruck and hot rod guys use them. they run about 130 dollars for one on ebay.
gmcjimmy88
Post by gmcjimmy88 »
Looks like a great idea if/when you get it to work. Keep us posted and post some pics if you do it.
