Pickup Box Trailer
Pickup Box Trailer
Has anyone made a pickup box trailer out of their bumpside? I'm considering buying a '69 3/4 ton parts truck and I'd like to make a heavy duty pickup box trailer out of it. My sense is to cut and bend the frame rails at the rear most cab mount. How far forward would I cut the frame rails? It looks like maybe just behind the front coil spring mounts? Are there any plans floating around on-line?
Greg Van Sickle
1969 Ford F-250 Crew Cab
2WD 360 2V C6 PS, PB, Onan Generator
- 72hiboy4x4
Cut the frame rails as far foreward as possible.
there is a hole in the side of the frame just foreward of the rear cab mount, cut the top and bottom flange of the frame there. use a come-along to pull both sides together. insert a piece of 2" OD x 1/4" wall tubing into the 'V' created by the rails, (I shoot for about 3.5 to foot from the bed for clearance) and trim the rails if needed. Line it all up and tack it in. double check it 2 or 3 times before and while you final weld it, cause it will distort on you as you weld. Reinforce the 2" tubing at the rear. Weld or bolt a coupler on the front end of the 2", install safety chains and a jack, wire the lights and go register it.
Its that simple.
I have one here I can take pics of if that didn't make any sense.![Laughing :lol:](./images/smilies/icon_laughing01.gif)
Its that simple.
- 19674x4
i made one for a neighbor, i cut the frame 3" before the bed, and made a tongue out of 3" channel, and 3"x1/8" square tubing, welded the tongue to the frame rails, and welded the box to the frame, then wired it.
My Photo Album
- trukcrazy
re: Pickup Box Trailer
Pictures, Pictures, Pictures- you guys know the rules.
![Razz :P](./images/smilies/icon_razz.gif)
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
![Image](http://www.fordification.com/images/forum/Signature-1.jpg)
- The Good Humor Man
http://WWW.GoodHumorTrucks.Com
- trukcrazy
Now Carl, you're just showing off.
Looks great, by the way and I am still jealous as heck. ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
John, #424
Pics would be great!
Greg Van Sickle
- ICEMAN6166
i have one, was given to me,its covered with snow so no pics.
![Image](http://www.fordification.com/images/forum/alaska-flag.jpg)
- 72hiboy4x4
heres pics of mine.
quick and dirty. Still need to reinforce the rear of the 2" tube and wire it for lights.
![Image](http://i20.photobucket.com/albums/b239/packrat169/Bumptrailertongue002.jpg)
![Image](http://i20.photobucket.com/albums/b239/packrat169/Bumptrailertongue001.jpg)
- trukcrazy
Hey guys, this should be done as a tutorial, hint hint.
While it is a relatively simple project, some of us are indeed "relatively simple" and need this kind of tutorial.
![Evil :evil:](./images/smilies/icon_evil.gif)
John, #424
Re: re: Pickup Box Trailer
Maybe a little...trukcrazy wrote:Now Carl, you're just showing off.![]()
