Tubular bumpers
TxCoyote
Tubular bumpers
Post by TxCoyote »
Is there such a thing? :?
Russ Rosenberg
67 Ford F250
68 Jaguar XKE
87 TVR 350i
74 Alfa Romeo GTV 2000
71 Triumph Stag (ford v6 conversion)
06 Saab 9-3 Sport Combi (company car)
trukcrazy
re: Tubular bumpers
Post by trukcrazy »
Hey Russ, welcome to the forum. Nice collection of vehicles, especially the Jag. Stop by the Welcome Mat and introduce yourself and be sure to include pictures of your collection. I am not sure what you are asking, but Ford had a tubular bumper option for the rear on the first gen Lightning. :thup:
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
get some well casing and weld caps on the ends and weld on some mounts. then paint and install.
FormerMarine1981
re: Tubular bumpers
Post by FormerMarine1981 »
:yt: You could also make the caps removable and store a chain in it. Have never seen it but was told about someone making an air tank out of a bumper. May not have been true though.
they have rear bumper made to hold air.
72hiboy4x4
Post by 72hiboy4x4 »
:yt:
They have full tube buggies that are joint drilled as they are assembled so the frame can act as an air storage tank.
ICEMAN6166
re: Tubular bumpers
Post by ICEMAN6166 »
i have made and had several with tube bumpers, minimum should be 4 inch pipe with caps welded on the ends.
