battery and light?
- rjewkes
battery and light?
Can a dead battery cuase the turn and emergencies to not work with the headlights on? TGhey work with the lights off and nothing is burnt or crossed i've checked.
- 72hiboy4x4
I take it you know for sure that the battery is dead? ie: the truck wont start/wiper motor wont turn/ect.
then yes, if its that dead I'm pretty sure the current draw of the headlights would cause the turn signals/4 ways to not work right.
- theskytoucher
re: battery and light?
my buddies got a 94 toyota corrolla that did kind of the same thing! except it was the alternator that caused the problem and on his when you would turn the blinker on it would turn off the radio/ thrid brake light!!! just my ![2 cents :2cents:](./images/smilies/icon_2cents.gif)
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
- Heavenlyfire
Sounds like what mine did when it died.
- rjewkes
ok. Yeah it wouldn't start and just clicked at the selenoid and like i said if i remove the headlights from the circuit then everything else worked like sppossed to. Will know for sure when i reinstall te recharged battery.
Thanks guys hope it was just a rundown battery.
You saw the effects of not enough current. Current will always take the path of least resistance. Starters are not the path of least resistance but when they draw or attempt to draw what they need everything else will lose the battle due to the windings sucking up every drop in order to work.
The headlights are the brightest object so when on at 12.5 volts they draw the most current because the resistance is lowest through the headlight filament. They draw 5.6 Amps (if they are standard lamps) for both and if nothing else turns on then that means the battery has 5.6 or less amps left in it.
- rjewkes
Yup! that did it recharged the battery and all is working again now to figure out the led thin as appearantly they don't draw enough to work as turn signals/brake lights with 2 or more on the same circuit.
