The right hand side high beam is a dead player on my 71 although the low beams work on both sides. I have done the obvious and changed out the headlamp. What's next? Also, in a possibly related issue I have no dash lights. I read another thread which suggested that this could be caused by a bad headlight switch. Is this a part you can get at the local parts store?
Gary
R/H high beam
R/H high beam
"Smoke me a kipper, I'll be back for breakfast"! - Ace Rimmer
1972 Donor "Green Monster" F100 Custom
1971 F100 Ranger XLT
1987 Corvette
1976 Datsun 280z
1948 Chevy Fleetline Aerosedan
http://www.fordification.com/galleries/ ... ?cat=10449
1987 Corvette
1976 Datsun 280z
- bluef250
- ICEMAN6166
re: R/H high beam
if the low beam works,the high should too unless the problem is in the plug or wire.
most trucks i have bought i had to replace the dash light bulbs in.
This may sound ignorant, but if the bulbs look good, i.e. not blackened and the filaments are ok, then shouldn't they be fine? The turn signal indicators work ok, is that a separate circuit?
1987 Corvette
1976 Datsun 280z
1987 Corvette
1976 Datsun 280z
