Steering column help !!
Bigfella
Post by Bigfella »
I'm looking for a place to order new bushings and whatever else for the steering column. I took mine out a couple days ago and the bushings just fell apart in my hand. I need parts quick !! I looked on the internet and couldn't find a place that carries them. Could any of you point me in the right direction of a place that sells them. Thanx a lot.
DuckRyder
re: Steering column help !!
Post by DuckRyder »
Dennis Carpenter has them.
Bigfella
Post by Bigfella »
How do I get ahold of him ???
http://www.dennis-carpenter.com/trucks.php
Be sure to order one of their catalogs.
DuckRyder
Re: re: Steering column help !!
Post by DuckRyder »
FORDification wrote:http://www.dennis-carpenter.com/trucks.php
Yep:
All 1967-1972 Steering Column Bearing Upper & Lower F100 C3DZ-3517-A 4.00 Each
All 1967-1972 Steering Column Bearing Sleeve Upper & Lower F100-250 Pic B1AZ-3518-A 5.00 Each
All 1967-1972 Steering Column Floor Seal Manual Steering F100-750 Pic C7TZ-3513-B 20.00 Each
All 1969-1972 Steering Gear Coupling Input Shaft to Steering Column Shaft C9UZ-3A525-A 75.00 Each
Trk FORD All 1965-1972 Column Gear Shift Arm Thrust Washer 2 per Column F100-250 C5TZ-7D363-B 2.00 Each
Trk FORD All 1965-1972 Column Gear Shift Lever Arm W Transmission Shift Arm Clip F100-250 379620-S100 2.00 Each
Trk FORD All 1967-1972 Column Gear Shift Lever Insulator Std Transmission 01A-7246-B 5.00 Each
Trk FORD All 1965-1972 Column Gear Shift Repair Kit Selector Arm Bushing & Insulator C5TZ-7343-A 10.00 Kit
Trk FORD All 1965-1969 Column Gear Shift Tube Before Serial #d96001 F100-250 C5TZ-7212-C 60.00 Each
Trk FORD All 1965-1972 Column Shift Lever Arm FOR 2ND & 3RD GEAR C5TZ-7302-A 20.00 Each
Trk FORD All 1965-1972 Column Shift Lever Arm FOR LOW & REVERSE GEAR F100-250 C5TZ-7303-A 20.00 Each
Trk FORD All 1965-1971 Column Shift Lever Spacer plastic F100-250 C9TZ-7336-A 4.00 Each
Trk FORD All 1972-1979 Column Shift Lever Spacer PLASTIC F100-250 D2TZ-7336-A 4.00 Each
Trk FORD All 1967-1972 Gear Shift Lever Insulator F100-350 Pic 1M-7246-A 5.50 Each
All 1970-1972 Gear Shift Lever Knob for column shift - Alum. -Chrome finish D30Z-7213-A 15.00 Each
Trk FORD All 1961-1972 Gear Shift Socket Lever Pin Automatic Transmission F100-350 357479-S 1.00 Each
Trk FORD All 1961-1965 Transmission Gear Shift Lever F100-700 with 4 Speed T98 Warner C1TZ-7210-C 33.00 Each
Trk FORD All 1967-1977 Transmission Gear Shift Neutral SAFETY SWITCH COLUMN MOUNTED C7TZ-7A247-A 80.00 Each
Trk FORD All 1967-1972 Transmission Gear Shift Socket Automatic Transmission use W C9TZ 7228 D3TZ-7A110-A 10.00 Each
Bigfella
Post by Bigfella »
Thanx guys. Now I'll be able to steer normally !!
