Ok, I am trying to correctly decipher the data plate on my NEW 68 F100. I get confused when it comes to the axle. The axle code is "E9". In looking at the breakdown, does that mean the "E9" is "3.54 - Dana 60-3"? And when it comes to the front axle code, where do I find that letter designation? Would that be the "E" in the "E9"?
Sorry to sound like an idiot, but I'm new to this and want to get my facts straight before I start digging in to this truck. Thanks.
G
Data Plate
- 71 LONG BED
re: Data Plate
Without seeing your VIN tag, I think your "E9" decodes as a 9,000 lb capacity front axle and 3.70 Ford rear, which is only a 3300lb capacity. I'm not sure what the exact axle up front is. Maybe another member can help with that. I'm going to poke around now, to see what I can see. Hope this helps a little. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
John Member #1549
![Image](http://weathersticker.wunderground.com/weathersticker/gizmotimetemp/US/NJ/Hamburg.gif)
![Image](http://www.fordification.com/images/forum/F-100sigpic.jpg)
![Image](http://i87.photobucket.com/albums/k131/haas522/F350/F-350sigpic-1.jpg)
re: Data Plate
Here's a photo of the data plate, if it helps. Thanks.
G
G
- theskytoucher
re: Data Plate
The reason you dont have a front axle rating is because your truck is a 2wd.
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
re: Data Plate
And the education of the GMan as to the ways of the vintage Ford truck continues. Thanks Troy.
G
G
Re: re: Data Plate
No, E9 shows a Dana 60 locker with 3.54 gears. All rearend codes are two-digit. That's a nice rearend, and those 5-lug Dana 60s aren't that common. I've got one in my '67 that came from a nicely-optioned '68 Ranger.71 LONG BED wrote:Without seeing your VIN tag, I think your "E9" decodes as a 9,000 lb capacity front axle and 3.70 Ford rear, which is only a 3300lb capacity. ...
re: Data Plate
You guys are the best. Thanks.
G
G
- 71 LONG BED
Re: re: Data Plate
I stand corrected.FORDification wrote:No, E9 shows a Dana 60 locker with 3.54 gears. All rearend codes are two-digit. That's a nice rearend, and those 5-lug Dana 60s aren't that common. I've got one in my '67 that came from a nicely-optioned '68 Ranger.71 LONG BED wrote:Without seeing your VIN tag, I think your "E9" decodes as a 9,000 lb capacity front axle and 3.70 Ford rear, which is only a 3300lb capacity. ...
Seeing the VIN tag helps decipher the way the code is written. When I went back to look at how I came up with that info, I realized I had misinterpreted what he meant by "E9".
![Not Worthy :bow:](./images/smilies/icon_notworthy.gif)
John Member #1549
