How much should I give?
mjhaltom
Post by mjhaltom »
What is a reasonable price to give for a PS setup at a pick and pull? I know where I can get one off of a '72 F250 Camper special. Parts would include sector, pump with cooler, pitman arm, brackets and steering column (an automatic that I can't use).
Or Can I use it? I wonder if I can get a smooth collar and put it on that column to use with a floor shifter? Any Ideas? What is all that worth?
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
gonzalo medina
re: How much should I give?
Post by gonzalo medina »
You have to be specific on exactly what components your getting. A good junk your rate usually will let you take the main gear for 40/50. The pumps range from 20-30 depending whether your taking the hoses which you shouldn't unless they still have tags and are clean. The steering shaft should leave for 15-20 buck.......These are CALI prices anyways. Hope I helped.
around here at the normal priced yards you will probably pay around 50.00 for a column. it could be 75- 125 though. steering boxes probably 50.00-75.00 for a good saginaw box would be ok. new i think i have seen them for 125.00 the pump 35.00 at the most. 25.00 would be better. i would not pay 50.00 for just the pump with or without the cooler.
mjhaltom
Post by mjhaltom »
I can get all the parts for $125 if I pull them.
1989 Ford F150
Levi W. Kring
Post by Levi W. Kring »
I'd say it's worth it if you have the time. :thup:
I love my "67
sounds like a deal.
gonzalo medina
What are you waiting for :wink:
mjhaltom
Post by mjhaltom »
Sounds like I'm just waiting on saturday to get here. Anybody need anything? The truck is complete.
1989 Ford F150
jhannahokla
Post by jhannahokla »
the salvage i go to sales steering columns for $25.00 :D
James
1970 F-100/302/3spd/9 Inc RearEnd 3.50 G/R
Image Watch This BurnOut !
