I have tail lights but no turn signals and no brake lights. where should I start my investigation? Is there a way to get a wiring chart for my 67 f100?
brake light and turn signal problems
- kknip
re: brake light and turn signal problems
Soitenly! Oh,a wiseguy!
You knucklehead!
![Image](http://upload7.postimage.org/222426/3gears.jpg)
65 Mustang
72 F250 Camper Special
You knucklehead!
65 Mustang
- 72hiboy4x4
![Welcome :wel:](./images/smilies/icon_welcome.gif)
start by looking at your turn signal unit in the steering column. all brake light and turn signal functions go thru there!
Wiring diagrams can be found in the tech and tutorials link at the top of the page.
Thanks so much!!!
I too had same problem, new turn signal switch solved it.
Jim
'75 Ford Highboy 390 4spd
