hillbilly67 wrote:Maxum96 #1- We are talkin about the torque converter here, not the transmission. And the bearings and bushings are always lubed with lithium grease for startup. This applies to converters and transmissions. On a used torque, there is always residual oil left. #2-The pump does not suck from the torque, it feeds it. Not filling a torque has nothing to do with knocking out a pump. If there was no oil at the pump, it had to do with the suction side, (pipe, filter/pickup, no oil in the pan, o-rings, valve body, blockage, etc) #3-You state "You'll never cause any increased wear or damage by prefilling."
Yes you can do damage by filling the converter. Simple. Same reason as not to prefill filters on a diesel engine. You are dumping in unfiltered oil. You run the risk of dropping contaminants into your bearings and bushings.
FORDification wrote:OK, settle down, hillbilly67....we definitely can benefit from your expertise and experience, but a friendly exchange of info is always more beneficial than an argument. Let's try to keep it civil, OK?![]()
