OEM/NOS WIRING HARNESSES
eking66756
Post by eking66756 »
Looking for sources for new wiring harnesses for our 72 F-250 restoration. I have found universal kits but prefer OEM/NOS to just "plug and play". Need body harness along frame, rear lights harness and engine bay harness. Any help out there??? Thanks. :?
ladz
re: OEM/NOS WIRING HARNESSES
Post by ladz »
We had just finished up a complete wiring harness form ron Francis and it went in with out confusion, they will make a wiring harness to your needs also ! The only thing we had to splice in was the ignition switch and get a dimmer switch !They have a harness for these trucks and there is plenty of wire for the hole truck ! The only thing i found is that when you get to the rear of the truck try to remember the lights for tags that is not supplied and in front a light for under the hood ! I do have a question on my electric chock Francis say to come off of the fuse box and in some forums in there they say from the stater on the alt.. this was the first time i have done this if i were to do it again i would lay it all out and wire tie all the rear lines and pull all at the same time! and the same with the front it would go a little faster . This company will help in a hart beet no please hold or music , individual packs of wiring with instructions for that steep it went well, i will go back to ron francis for my next project !
...and that's going to be about your only option. There's no aftermarket vendor manufacturing direct-replacement OEM-style wiring harnesses for our trucks, though there are several (like the Ron Francis setup) that will require some adaptation. Our trucks are just not popular enough to warrant the production costs.....yet. ;)
