80's wiper delay
80's wiper delay
Hi all, I'm attempting to wire in a 80's wiper delay switch and relay in a 72 F100 2wd. Does anyone have a wiring diagram for a 72? When I attempted to follow the directions in the fordification tutorial, I wound up with one speed working, pump working, but no delay and no second speed on the wipers??? Have no clue what I'm missing here.
Proud member of the Ford Drag Team
Yeah, read that...several times. Doesn't work that way on mine. Don't know if it's my trucks wiring, or if the 80's delay unit is NFG. That's why I need to see a wiring diagram for a 72.fordman wrote:www.fordification.com/wiring.htm
- 71 LONG BED
re: 80's wiper delay
I thought it was just plug-n-play.
John Member #1549
So did I. Assuming it should be, I'm wondering if my trucks wiring has been altered (looks original) or if there's something wrong with the switch I got.
- 72hiboy4x4
heres a pic of the wiring for a '88 F-350 int. wiper switch.
Dunno if it will help.
Thanks Hiboy, that should help. I can at least compare the wiring to my 80's switch...
