transmission hump question
55vicky
Post by 55vicky »
My truck has the lower transmission hump. Am I going to have to make it
taller to accept the np435?
Thanks, Dave
re: transmission hump question
Yes. Trucks with FMX/C4 automatics and 3-spd manuals got the solid transmission hump , while C6 and 4-spd trucks got the bolt-on cover which raised the hump up several inches to clear those large transmissions. You'll have to cut out the factory hump to allow you to bolt on the taller cover.
67highboy
Post by 67highboy »
You will need to cut it out and get one of the bolt in humps that the trucks with 435's had.
I have one in the garage you can have for the price of shipping...
People who are willing to give up essential liberty to purchase temporary safety, deserve neither liberty or safety...
Ben Franklin 1775
55vicky
Post by 55vicky »
Thanks for the picture Keith, and now that I looked at it looks the same height as mine. I have a C6, tranny cover has the dog leg, PO put in a floor
shift and it doesn't protrude from the hump, it's flush. So maybe it's ok
after all. Haven't had the original floor covering up yet to see if it has the
bolt on cover.
I wonder why the data plates have all the different manual trannys listed
but only says automatic for the "G" code? The reason I mention that if my
truck was built with a 302, one would think it would have a C4 and maybe
the lower tranny hump, especially with a column shift (it still has the shift
bowl for column shifter. Did they put C6's behind 302's?
Thanks, Dave
BTW, I posted on the meeting place finally
i'm sure they did put c6 behind 302. they are a small block 302. but it depends on the year of your truck though. 302 came out in late 69 in our trucks.
They simply state 'Cruise-o-matic' in the codes, since that shows it came with one of the several automatic transmissions in the Cruise-o-matic family.
More than likely your 302 would have been equipped with a C4, though as fordman stated it's possible to have had a C6 with the small-block bellhousing bolt pattern, but not likely.
C6 trannies will fit under the stock floorpan, so it's not really necessary to cut it, but it's a very tight fit. As you can see from the pic above, the 4-spds definitely needed the taller hump.
68F250
Post by 68F250 »
I thought the first year F100/150 with a 302/C6 combo was '79. :hmm:
Barry
Re: re: transmission hump question
68F250 wrote:I thought the first year F100/150 with a 302/C6 combo was '79. :hmm:
Really? I honestly had no idea, I was just assuming otherwise. (Of course, that's gotten me into trouble before!) ;)
Thanks Barry....very interesting. I'll definitely remember that. In fact, I'm going to add that to the Did You Know box. :D So just to make sure I have my facts straight, prior to '79 all small-block automatics were the C-4, correct?
i had a 78 with a 302 and a small block c6 in it. f150 custom
68F250
Post by 68F250 »
Don't quote me yet, it could really be '78. My info for that year is a little shy and doesn't show it but I've heard of some and Fordman adds to that list. For sure not in '77 or earlier and for sure '79 and later. :D
So, prior to that the 302 would have either a C4 or starting in '74 an FMX.
Barry
mjhaltom
Post by mjhaltom »
If you cut out the solid floor, what are the mounting options for the bolt on cover? Will tabs have to be fabricated?
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
you will need something to put a cover back on with. or if your real good cutting it out you can cut tabs out of the floor panel that is there. drill holes use the j nuts and put a cover on. i think it could be done but you would need time and patience.
I agree, just cut the floorpan out like the factory would have done it, around the molded-in tabs that are already there. Then just drill a hole in the center of each tab and slide a J-nut on, and bolt the cover down.
Here's a couple pictures I shot while repairing and sandblasting a cab, that shows how the factory-cut hole should be. The first pic shows the bottom of the cab, while it was up on it's back and I was replacing some cab supports:
...and this picture was taken inside the sandblast booth, when I was about 99% done with the blasting:
Tim P.
Post by Tim P. »
Ok so let me get this straight guys the only difference between the high hump and low is the cover added or deleated at factory going down the line.
GT-Racer
Post by GT-Racer »
whatever you choose please dont do it like this......
http://rides.webshots.com/photo/1122057 ... 2214KrLKDF
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
