Hood?
theskytoucher
Hood?
Post by theskytoucher »
On my hood the sheet metal is not connected to the inner support. I was wondering if it was suppossed to be or not?
THX
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
no its ok
theskytoucher
so this is a normal problem?
-Troy-
1976 Ford F-150 4x4
69rangerman
re: Hood?
Post by 69rangerman »
Mine is the same. I got goofy headed a while back and decided to climb up on the hood. It didn't budge. That support webbing under the sheet metal is tough - it just looks flimsy when you're driving and it's doing the shimmy.
jzjames
re: Hood?
Post by jzjames »
I thought the sheetmetal was supposed to be glued to the support frame with some adhesive. Mine is also disconnected, I think from when the hood went flying up on the interstate onramp.
theskytoucher
re: Hood?
I also thought it was supposed to be glued down but hey if it anit gonna hurt nothin im gonna leave it alone.
-Troy-
1976 Ford F-150 4x4
mrsnicks
Post by mrsnicks »
My hood does have some goop? glue? in a couple spots where it has oozed out from between the inner support brace and the hood skin.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
yeah i think they orignally had some sort of goop to hold them together but i don't know that it can be fixed. you could try urethane for windshields. that stuff does work good on glass to metal so it should work great metal to metal.
theskytoucher
I was thinking of jb weld to put them back together. Any thoughts on that?
-Troy-
1976 Ford F-150 4x4
jbwled might work. but what i think is that jb weld is a soild type of adhesive. it doesn't have any flex to it. the hood skin does flex when not attached to the bracing. so you know that it will want to flex when attached to the bracing.
theskytoucher
Good point. I just want to get my hood so that when you set your had on it it doesnt 'pop' down. IF you know what i mean.
-Troy-
1976 Ford F-150 4x4
yea i know what your saying. you just want something to hold it in place so it doesn't seem so flimsy
mikecarson
re: Hood?
Post by mikecarson »
Some sort of caulk, like you'd use around the house? A lot of that stuff remains flexible, but would hold the metal in place.
SmokeyBear
Post by SmokeyBear »
Seam sealer. Just enough flex to prevent warping.
70 F-100 XLT
72 F-100 Ranger XLT
