Trailer Wire Hookup Help
cghstrojan08
Post by cghstrojan08 »
What should I do to hookup a simple 4 point trailer hookup?
ROBERT
Member #1076
1968 F100 SWB 360
brown is brake tailwhite is ground or neutral yellow and green are the turn signals but i can't remember which side is which use butterflies to hook in the under bed wiring. they should be those colors also.
72hiboy4x4
Post by 72hiboy4x4 »
