I bought a set of helper springs from an 80's F350 off ebay. They are an exact bolt on fit for my bumpside. It seems Ford used the same perches for quite a while. They are the same on my '96 too. I think that the Superduty uses a different setup. I don't know if the 1/2 and 3/4 ton bumpsides have the holes in the frame or not. The hardest part was getting the rivets off the perches. I had to buy new U bolts, not just because of the rust, but because the old ones are too short. The truck now has 11 leaves in the main spring, and 4 more in the helpers. The ride, when unloaded, is unaffected. I'm guessing that this would bring my MGVW up to 10,000lbs from 8300lbs. An easy upgrade.
I think this is a link to a photobucket album. If you view it as a slideshow it should be in order.
http://s115.photobucket.com/albums/n298 ... ersprings/
Added helper springs to my F350
- FLATBEDFORD
Steve
My Photo Gallery
My Photo Gallery
- 72hiboy4x4
My F-250 4x4 has the holes for the perches.
I took a set of springs from an f-350 and put them on my truck. Like you, I had to replace the U-bolts due to length. But I also needed to keep the lift blocks.
Then I had to do it all over when I put the dana 70 rear axle in.
The '68 F100 that I pulled a set from only used 3 of the four bolt-holes in the frame brackets. I compared that frame to the '72 SWB F100 frame I have and the three holes are there as well...I'll just have to drill one hole if I decide to use all four, which I probably will.
My 72 as well has the holes in the frame Im still looking for a set of factory pearches mine have the dealer add ons which are ok but factory look better and stronger.
- cooltoolguy
- FLATBEDFORD
You do? Let me know if you want to get rid of it.cooltoolguy wrote:I picked up a set from a 79. the main pack is 13 leaves and the helper is 5 or 6, plus a rear stabilizer bar and a front stabilizer bar for about 200 BTW I have an extra 350 front disk setup
Steve
My Photo Gallery
My Photo Gallery
