How many guys does it take to move a cab?
dablack00
Post by dablack00 »
Ok, I'm looking into buying a better cab for my 68 project. Without a hoist or anything else, how many guys will it take to put a cab in the bed of my 71 short bed.
Will a cab even fit in the bed of my 71 short bed?
thanks
Austin
a minunm of two. it will barly fit in the back of my 94 250.it will only go to the wheel wells before it has to be lifted over them. so four guys would be better.
dablack00
Post by dablack00 »
Sounds like it isn't going to fit in my short bed. Is that what I'm hearing? I thought it might fit turned sideways.
thanks
Austin
flyboy2610
Post by flyboy2610 »
I just went out and measured the cab on the '68. No, it wont fit between the wheel wells. Turned sideways it will go in the bed but not between the wheel wells. You may want to get a U-haul trailer or something.
Sorry. :(
mrsnicks
Post by mrsnicks »
It depends on the guys... my best friend and I can move a cab without removing seat, tank, column etc... Of course we're both well over 6' and 275lbs.
I would say at LEAST 3 average sized guys to move it, and 1 guy to watch for snagged lines and wires... or things that didn't get unbolted.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
67F250CS
Post by 67F250CS »
Well I totally stripped my cab and I moved it by myself. Doors and all off. No glass. You get the idea. I turned it upside down and it fit in the bed no problem at all. Its a lot narrower upsidedown and the cowl clears the wheelwells. I borrwed (took) some old thick comforters from my wife, and stufeed them around for padding. Shes always changing colors so we have a few. I just put a piece or 2X6 to prop it up.
1967 F250 Camper Special
dablack00
Post by dablack00 »
Upside down? You have got to be kidding me!
The cab I'm might be getting is already stripped of doors and interior, nothing much left, but the cab it self and some wiring. It is also already off the truck so there is nothing to get caught.
I'm going to think about the upside down thing. That might work. I will just have to tie it down really well and make sure it is really padded under the roof.
Also, fb2610, going out and measuring was way beyond the call of duty. I apreciate it.
Austin
flyboy2610
Austin
Hey, we're all in this together! :wink:
No problem. Glad to help.
I'm glad to hear you forgured out a way to get your cab home.
