ok i have a qustion i'm goin to be purchesing the following of the Summit website. the bolded text is the part number
BFG-57974 BFGoodrich All-Terrain T/A KO Tires $209.95
WVI-10-7812042 Wheel Vintiques 10 Series Chrome Smoothie Wheels $199.39
These rims are 17"x8" with a 4.5" to 4.75" bolt pattern (tires will fit these rims i think)
anyways he questions are......
1.Is this the correct bolt patter for my 1967 ford f100?????
2. will those rims fit those tires?
3. I've read recently you need a brake booster thing for rims/tires over 16"....is this true???
4.If number 3 is true what is the part and how much (and where) do you get it?
thanks,
Nick
one smal wheel/tire question/brake
re: one smal wheel/tire question/brake
ford truck lugs are 5 x 5.5 unless you have a car then its smaller.
- green70
my brakes work fine with 17" wheels,my tires are smaller though,i would at the very least upgrade to disc brakes if you dont already have them....
5x5.5........dang it i can't find a rim that fits that
Nick
Nick
- willowbilly3
I am sure WV would have the 5.5 bolt pattern since all the older (pre 49) Ford cars use that pattern. I'm not sure what size tires those are but my personal preference is to keep with a tire that is at least 28 inches tall or the whole balance of the truck gets out of whack. They just have to have some sidewall to look right. Some 265-60 on 17s should look pretty good.
- green70
summit also carries the us wheel smoothy,looks the same but a lot cheeper,plus it come with a cap and they have them in 5-5.5
- green70
heres a link to the painted ones,they come in chrome also...
http://store.summitracing.com/partdetai ... ppfilter=1
- green70
wv lists up to a 16x10 in 5-5.5 on there website,you could try www.stocktonwheel.com they can build you anything you want,you brakes should be fine as long as you have front disc....
