speedo cable
19674x4
speedo cable
Post by 19674x4 »
i guess this would be the place to put this.
while driving home the other day a horrible grinding noise began and my speedo began freaking out. so i slowed down to what i would guess to be about 20 mph and the grinding stopped but the speedo kept wobbling. so i picked up speed and it started grinding again the the speedo needle dissapeared and it hasn't came back up since. it's a brand new cable. Whats up :?
My Photo Album
ToughOldFord
re: speedo cable
Post by ToughOldFord »
Sounds like your speedo died, have you noticed if your odometer is still working?
19674x4
Post by 19674x4 »
i havn't noticed i'll have to look
My Photo Album
72hiboy4x4
Post by 72hiboy4x4 »
did you lube the new cable? bet it seized up on ya!
flyboy2610
re: speedo cable
Post by flyboy2610 »
If it's the speedo, I have one I can sell you.
It worked when removed from the truck. Let me know.
19674x4
Re: re: speedo cable
Post by 19674x4 »
ToughOldFord wrote:Sounds like your speedo died, have you noticed if your odometer is still working?
the odometer does work, i just checked
My Photo Album
Leadfoot
re: speedo cable
Post by Leadfoot »
could be the speedo gear is NFG. or even worse the gear in the trans is stripped.
WHAT ?
ToughOldFord
Then the cable's good, your speedo died.
flyboy2610
flyboy2610 wrote:If it's the speedo, I have one I can sell you.
68F250
re: speedo cable
Post by 68F250 »
Is there any relationship between installing a new cable and the speedometer dieing? Sounds like the cable is still turning.
Barry
