Roof-Mounted Clearance Lights
ejgator
Post by ejgator »
My restoration is in it's final stages, and I'm giving some thought to these before installing the headliner. Anyone have any opinions, either as to the look when installed, or the installation (mainly the placement of five lights)?
As soon as I get the windshield and back glass installed, I'll try to learn how to post pictures. I do have a digital camera and have sent pictures via email, so I should be able to post them here,,,,eh?
68 F100 Ranger, 65 Galaxie Ragtop, 71 LTD, 84 Ranger
Ford_Doctor
Post by Ford_Doctor »
It's a matter of personal opinion and personally I don't care for the cab clearance lights unless it's heavier truck meant for hauling.
72hiboy4x4
Post by 72hiboy4x4 »
technically, if you are hauling/towing something over 80", you must have 3 center mount lights visible front and rear.
I like the look personally, but then I drive a big rig for a living.
I can get a pic of the placement of mine if you want. the lights themselves are no good, but it will give you an idea where they go from the factory.
Galaxie64
Post by Galaxie64 »
I don't much liike them myself, my '72 has 5 of them and I am thinking about removing and filling the holes. I should say I like the look of them at night with them on but not in the daytime when you can really see the truck lol
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
rjewkes
Post by rjewkes »
Some dots(depart. Of Transportation) Require the three center ones to be right next to each other and then the other two on the far outside. Othres don't care and others still require tehy be 12-24" appart.
I put my first one on dead center all the way out tell the cabs beveled edge just about the chrome.
and then spread them out on that line with IIRC 24" appart. I nstalled it center, both outer corners then the two inners.
ejgator
re: Roof-Mounted Clearance Lights
Post by ejgator »
Thanks for the responses. Yeah, 72Hiboy, I would like to see them. If you can post a pic of them like at dusk, with them on, that would be great, but any pic will do.
The thing that appeals to me is related to the look of the amber parking lights shining next to my new paint. I'm thinking the clearance lights would kinda have that same effect.
72hiboy4x4
I'm not sure all of them even work anymore, but I'll get a pic of whats left tonight. and I'll get a pic of my '88's running lights also, for comparison.
71 LONG BED
Post by 71 LONG BED »
Here is where mine came from the factory. I'm not at home so I can't take any measurements right now. If you need them let me know and I'll get out there with a tape measure and jot down some numbers for you. Hope this helps.
John Member #1549
Image Image Image
hardtailjohn
Post by hardtailjohn »
:yt: That's the way I like them!!
JH
72hiboy4x4
:yt: thats where mine are, also. just not in near as good of shape as that! :lol:
ejgator
Post by ejgator »
That's a big help, Long Bed. If you have a chance to get measurements, I will appreciate it. I think consistent spacing close to this will probably work just fine, if I do install them. It's also good information about an F100 with factory clearance lights.
Gator
71 LONG BED
I'll measure 'em up tonite when I get home, ejgator and post the dimensions for you. :D
John Member #1549
Image Image Image
Galaxie64
Post by Galaxie64 »
Interesting, I wonder if they changed the spacing in '72 or if mine aren't stock. Mine are spaced equally between all 5.
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
71 LONG BED
Re: re: Roof-Mounted Clearance Lights
71 LONG BED wrote:I'll measure 'em up tonite when I get home, ejgator and post the dimensions for you. :D
Sorry, I didn't have the time I thought I would have last night. I measured them up this morning. The 3 middle ones are 9 inches, on center, apart. The outer ones are 23 1/2 inches from center or 14 1/2 inches from the one next to it. They are also set back 7 1/4 inches from the drip rail to the FRONT of the light. Hope this is enough info. Let me know if you need more. :D
John Member #1549
Image Image Image
ejgator
Post by ejgator »
Thanks for the extra effort, Long Bed. That's exactly what I need. I will assume, unless you tell me otherwise, that they are set in a straight line from side to side, not in a curve.
